Mk1 wider track/stance (mk2 running gear)
Sal
#1 Post by Sal » Fri Sep 10, 2021 6:04 am
Hello there,
I recently bought a mk1 and I understand a lot of people put mk2 running gear on as that widens the wheels/stance and therefore the wheels fills the arches better (not for the purist of course) but I certainly prefer that look.
What is required to be changed on the front and rear to get the wider stance?
Sal
Re: Mk1 wider track/stance (mk2 running gear)
#2 Post by Charles H » Fri Sep 10, 2021 7:55 am
The front is the same, and the rear needs Mk2 trailing arms and driveshafts. Quite easy really.
Sal
#3 Post by Sal » Fri Sep 10, 2021 7:38 pm
Thanks Charles although thought the front hubs were wider? No?
#4 Post by Alec » Sat Sep 11, 2021 7:20 am
Hello Sal,
what Charles posted is correct but I would add that the handbrake cable needs to be extended. I made up a steel strap which bolts between the horseshoe shaped cable link and the main cable, This worked well for me and was very simple to do.
#5 Post by johnnydog » Sat Sep 11, 2021 9:33 am
Alternatively, would it not be as simple to fit Mk2 handbrake cables whilst everything is being disconnected? They are available quite cheaply.
xpi
#6 Post by xpi » Sun Sep 25, 2022 4:54 pm
Hi if you fit the mk2 wider track set up you will then struggle to fit wider wheels even 51/2" tr6 wheels tyres will more than likly foul the rear arches, just to let you no :D
