Overdrive for a 2000 Mk 1
Roscoe
#1 Post by Roscoe » Thu Jun 03, 2021 10:59 am
Is it possible to fit a complete gearbox with overdrive to a 2000 mk1 in place of the standard 4 speed.
I assume that the overdrive takes the place of the rear gearbox extension piece on the standard 4 speed, was thinking of getting one from rimmer brothers if they have one.
bigestate
Re: Overdrive for a 2000 Mk 1
#2 Post by bigestate » Fri Jun 04, 2021 8:54 am
Hi Roscoe Yes it is basically a straight forward swap, I have done plenty.
You will need different length spacer tubes depending on what type of overdrive box you intend fitting. Some types are compatible with Automatic tubes not sure which though.
The biggest expense will be the overdrive column switch if you don't go for the MK2 gear lever which incorporates the switch.
Roscoe
#3 Post by Roscoe » Fri Jun 04, 2021 10:44 am
Thanks bigestate will a mk2 gearbox fit the mk1 engine if I can’t get hold of a mk1
sahtuning2000
#4 Post by sahtuning2000 » Sat Jun 05, 2021 11:45 am
Hi Roscoe
I have a complete MK1 mabnual overdrive setup that iam thinking about selling including the rare column switch and all wiring.
PM me if interested.
Richard B
#5 Post by Richard B » Sat Jul 03, 2021 8:15 pm
A Type fits direct to the bodyshell, no spacers required. J Type requires spacers, CW sells them I think they are longer than the auto gearbox ones.
Richard
Compulsive PI'er :) Daughters have Heralds. Son-in-laws have 2.5's
