Morning all,
Is it possible to identify what ratio a diff is from any external markings or will I have to strip it and count the teeth?
About twenty years ago I transplanted the complete rear subframe/suspension/diff assembly from a very low mileage Mk2 2.5 PI (which think was an automatic) into my manual Mk2 2.5PI.
At the time I didn't give any thought to the fact that the diff ratio was different but now I'd like to establish whether it's a 3.7:1 auto or 3.45:1 manual diff.
Diff identity
Re: Diff identity
Theoretically, assuming it was the correct diff in the auto PI when you did the original swap, it should be a 3.45 ratio. As long as it hasn't been stripped and messed about with previously, the easiest way is to check the identification letters stamped into the casing which should be MG for a 3.45 diff (a 4.1 is stamped ME, and a 3.7 is MEC). Also there should be a splash of red paint on the large nut of the driveshaft output put flanges. If the paint is yellow or white, then its is a 2000 diff (either 3.7 or 4.1 - can't remember which is which).
As you are no doubt aware, 3.45 diffs were fitted to both autos and manual 2.5 / 2500 cars, so it is irrelevant which transmission the donor car had. The rear cover and mounting plate can be swapped over depending on whether saloon or estate.
Re: Diff identity
Thanks very much for that information Johnnydog - I'll inspect the diff tonight to see what I can find.
For some reason I thought 2.5 autos all had a 3.7:1 ratio!
Re: Diff identity
Whatever the markings, whatever has actually been done, the ultimate test is to jack up one wheel and count the turns of the prop v turns of the raised wheel, and double (? or is it halve ? ) the ratio.
