Gearbox oil change
I've changed the oil in my J-type overdrive manual gearbox - do I need to re check the level after some driving to account for the overdrive unit taking up some of the oil, or will the OD not have drained when I drained the rest of the box via its sump plug? Cheers.
1977 2500S - White
1977 2500S - White
Re: Gearbox oil change
I think it's considered a good idea to drop the overdrive sump and clean the filter - there's a magnetic ring too to collect swarf. That of course would drain the OD oil as well.
If you drop the O/D sump, you’ll need to replace the gasket.
Chris
Member 7910
Magenta Stag 3.0 Man O/D
Member 7910
Not if you are careful
