Gearbox differences
Gearbox differences
#1 Post by johnnydog » Tue Mar 13, 2018 10:08 pm
I am planning on fitting a replacement 'A' type manual overdrive gearbox to a 1973 PI.
The only good used 'A' type gearbox that I have is from a 1973 2000.
Looking at the official Triumph manual, the MK2 PI gearbox was identified by the letters MD, whereas the MK2 2000 gearbox had the letters MB.
Does anyone know the actual difference between the two?
Re: Gearbox differences
#2 Post by Charles H » Wed Mar 14, 2018 12:34 pm
I think that the gearbox is the same, but the A type OD has different springs, (either number or strength or both). The OD can of course be moved from one to the other unless the OD is the problem with your existing 'box.
Pimento Red Stag
#3 Post by johnnydog » Wed Mar 14, 2018 7:42 pm
What difference do the springs make? Is it something to do with the greater torque being transmitted through the overdrive unit when engaged?
#4 Post by Charles H » Thu Mar 15, 2018 10:48 am
Basically yes! Not my specialty, maybe have a chat with CW!
Pimento Red Stag
CAR
#5 Post by CAR » Sat Mar 17, 2018 2:48 pm
I had an MB A type box on my pi when I got it John and it made no difference tbh. Not sure if it had the PI O/D on it or 2000 one. It still worked fine, even on a couple of trackdays.
I spoke to Andy Roberts about it and he said basically the same as Charles.
#6 Post by johnnydog » Sun Mar 18, 2018 11:05 am
I appreciate the info Charles / Colin - thanks very much! So when the PI turns up on the camp site in Paignton with the caravan on the back, you'll know its been ok!
#7 Post by Charles H » Sun Mar 18, 2018 11:48 am
Looking forward to seeing you there.
Pimento Red Stag
