Master Cylinder
peewee21
Master Cylinder
#1 Post by peewee21 » Sun Apr 02, 2017 6:05 pm
Hi All,
Stripped of the master cylinder and reservoir today, the fluid was rotten as was the reservoir itself. couple of quick questions,
for a mk1
1, are the repair kits any good?
2, where am i amble to get hold of a new reservoir?
kind regards
Ian
Ian Peacock
still sane? definitely not!!
Mk1 2000 Estate Wedgwood Blue
Re: Master Cylinder
#2 Post by johnnydog » Sun Apr 02, 2017 11:15 pm
I am assuming your car is a late Mk1 and has the clutch master cylinder with a seperate reservoir on top - as on the Mk2's?
As long as the bore is in good order with no scoring or corrosion, then a seal repair kit would be OK.
The Mk2 clutch master cylinder is getting harder to find at sensible money - CW is asking well over £100 for the cylinder alone, but when I checked recently, he was out of stock. It doesn't come with a reservoir either.
The reservoirs are like the proverbial rocking horse to find, especially new. I have seen autojumblers asking £60 for them! A good secondhand one would be the viable option - if you can fnd one!
sprint95m
Okay....
#3 Post by sprint95m » Wed Apr 05, 2017 10:18 am
Later mark one and all mark two?
The reservoir is the same as a Dolomite Sprint.
A Dolomite Sprint master cylinder could be used, it is the same bore. (Fit helicoils into the mounting flange?)
New MCs are also available from kit car suppliers. They also do reservoirs but these are much bigger (but still useable).
Re: Master Cylinder
#4 Post by Mike Stevens » Wed Apr 05, 2017 11:51 am
The Stag uses the same reservoir but I think the master cylinder may have a different bore diameter.
sprint95m
Yes......
#5 Post by sprint95m » Thu Apr 06, 2017 9:56 am
A Stag MC bore is indeed bigger,
however you change the slave cylinder (from 7/8") to 1" bore to allow for this.
Ian.
peewee21
Re: Master Cylinder
#6 Post by peewee21 » Wed Apr 12, 2017 7:37 pm
Thank you all for the info
Ian Peacock
