Quicker Gear Change
My 2000 overdrive gearbox is fine for relaxed driving, and is very much the same as the other 70s cars that I have driven over the years. However, it is hopeless for more 'spirited' driving as the throw is a bit long and vague.
Is there options for making the standard gearbox more precise, or is there a suitable replacement? I'm very slowly building a fast road car...
Re: Quicker Gear Change
Back in the day (with friends Capris) we used to shorten the lever. Not sure if it made much difference but like side stripes it gave the impression of a faster change.
Quicker Gear Change
Do you have a short or a long gear-lever? The short one is much better and quicker.
Vague? Never found that. Have you adjusted your gear-lever correctly? Did you know you can adjust the play out?
The box has always felt direct and sharp to me, but the gate is quite wide.
Rover R380 box is nice and I think it would fit without much modification, but personally, I'd miss the overdrive!
Chairman
Chairman
- Andy Thompson
Short gear stick (pre-facelift) and fully synthetic gear oil. Easily as good a R380 - got one of those in the Disco and it's about as good as a Triumph and very similar when cold!
Perth WA
1970 2500PI estate
1964 2.7PI saloon
1973 2100 EFI Megasquirt
1972 Stag
Very Big garage
1970 2500PI estate
1964 2.7PI saloon
1972 Stag
Very Big garage
- david_lall
Don't know if it's just how I drive but I find double de-clutching is quicker - especially when I'm having a thrash!
David Lall
1978 Carlight Casetta Caravan
Double de clutching generally makes the gear change smoother by reducing any 'baulking' and making the change easier, and therefore probably gives the impression of quicker gear changes.
Mention double de clutching to anyone half our age, and they will probably not have a clue what you're talking about!
I have to double de-clutch on my Land Rover. It has synchro only on 3rd and 4th!
Yet another dying art...
- johnconradlee
Syncromesh on all forward gears was one of the selling points of the Triumph 2000. Don't think the 4 speed Vanguards did.
Going back to the original post, the question I'd have if you are finding the throw a bit long and vague is how worn is your gearbox/linkages. The gearbox in the Mk2 I used to have a few years ago was definitely much sharper and more precise than in LuLU my MK1.
John Lee
