Gearbox oil cooler
sahtuning2000
Gearbox oil cooler
#1 Post by sahtuning2000 » Fri Jun 05, 2015 9:17 pm
Did Autos P.Is come standard with gearbox oil coolers?
Damm thing fitted means i can,t fit a spin on conversion as it hits the oil cooler pipes to the gearbox.
Re: Gearbox oil cooler
#2 Post by tony » Fri Jun 05, 2015 9:40 pm
As far as I know all Mk2 Auto's were fitted with oil coolers.
#3 Post by Alan Chatterton » Fri Jun 05, 2015 9:56 pm
Standard on 2.5, not sure it was on 2000
TedTaylor
#4 Post by TedTaylor » Fri Jun 05, 2015 10:41 pm
Fitted on my Mk1 PI estate.
Mind you I could do with a better one if anyone has one going spare or something. It is the correct tubular type and the fins on mine are getting in a bit of a state!
MUT
Lloydpiestate
#5 Post by Lloydpiestate » Sat Jun 06, 2015 5:55 am
i've got an oil cooler on mine, and i've got a spin on.
the cooler has standard pipework as far as i know, perhaps i should have a closer inspection ?
Jonathan Lewis
#6 Post by Jonathan Lewis » Sat Jun 06, 2015 9:10 am
As Alan has already said, standard fitment on Mk2 2.5/2500s but special order only on 2000s, at least for the home market. Export models and those built overseas might have different arrangements...
#7 Post by Alec » Sat Jun 06, 2015 9:15 am
Hello SAH,
not knowing quite how the gearbox oil cooler lines run, this is a bit of a guess. You don't have to install the spin on filter vertically, it can be fitted at an angle, will that give sufficient clearance?
Polly
Gearbox oil cooler
#8 Post by Polly » Sat Jun 06, 2015 9:52 pm
I fitted an oil cooler on my export market 2000 Mk1.
I also have a spin on filter, I can't remember any problem with the pipe work fouling the oil filter. The pipe work is attached to the sump bolts, but I would think it would be quite easy to bend the brackets a little to provide clearance
Triumph 2000 Mk1 Slate Grey
Triumph 2.5 PI Mk2 Damson
Landrover Discovery 3.9 V8
Reliant Kitten
MGZS
MGZR
