englishbull
Re: converting a bw35 to modern 4 speed autobox, anyone? #11
Post
by englishbull » Tue Oct 25, 2011 9:04 am
Thorsten wrote:Cheers, Harvey,
I hope you'll keep us updated on the evaluation process...
Best regards
Thorsten
Yes I would be keen to do this to Thorsten.............
sorbs - Senior Member
#12
Post
by sorbs » Wed Oct 26, 2011 6:51 pm
I always fancied fitting an overdrive to my 2000 BW35. The idea was scoffed at at the time so it's nice to hear it's been done!
I never got round to it and just bought a car with a 4 speed auto instead........
I'd always liked the idea of the overdrive being automatically engaged which would have needed a speed signal, load or throttle position signal and a little programmable control unit to get it to switch in and out as required.
Andy Thompson
Post
by Andy Thompson » Thu Oct 27, 2011 5:11 am
There is an Aisin Warner 4 speed auto - fitted to some Volvos and the Toyota cressida
My mate has one on his Stag - so it can be made to fit
A40D
Four speed automatic
Applications:
1977-1980 Celica Supra
1983-1986 Celica Supra (Australia)
1981 Corona
1981 Toyota Cressida
The AW70, 4 speed auto (without lock up clutch - controlled 4th gear 'overdrive') 240 series, B23F engine.
http://v1800reg.org/pages/AW70%20CONV.PDF this might help
#14
Post
by Alan Chatterton » Thu Oct 27, 2011 1:46 pm
a company called tate and lewis off the ZF 4 speed auto (22HP I think) into the stag. Simple ish conversion with a special adaptor plate.
a friend of mine enquired about a saloon, it could be done but there might have to be some minor tunnel "mods" (big hammer!) to make it fit.
Driven a stag with this box and its very nice indeed.
Problem is the cost, £2500.
Dave Hosegood fitted a AL4D box from a Granada Scorpio to his car, full write up including all the tech details on how he did in Sixappeal a few years back?
CAR
#15
Post
by CAR » Thu Oct 27, 2011 2:36 pm
Dave did indeed do the conversion and a write up in SIXappeal a while back, he lives close to me although I haven't seen the car. It was said to be very good.
The Stag conversion at £2.5k seems a bit steep, a gearbox out of a later BMW would seem an excellent choice, Dad's '96 323i has a 5speed ZF switchable box that does just under 2000rpm at 80mph. He manages to get a true 39+mpg from that 2.5L car coming up to visit us at a steady 70mph.
There must be loads of those E36s in the breakers now, all it needs is someone with an engineering background to prototype a conversion. The box, electrics, mounts and prop ought to be £150 tops from a scrapyard.
TR7Driver - Newbie
#16
Post
by TR7Driver » Tue Nov 01, 2011 7:17 pm
CRAJ wrote:Dave did indeed do the conversion and a write up in SIXappeal a while back, he lives close to me although I haven't seen the car. It was said to be very good.
Hi Colin, Don't 'spose you could get Dave to repeat the write up or attach it to the forum?
Jim
Jim S
TR7Driver - Newbie
#17
Post
by TR7Driver » Tue Nov 01, 2011 7:23 pm
Just got back from Reigate, via M4. Speedo shows 78/80mph, rev counter shows 5000rpm, tomtom shows 70mph! TR8 would be doing about 2100rpm. Is the autobox at fault? or do I need to change the diff?
Jim
Jim S
Thorsten
#18
Post
by Thorsten » Tue Nov 01, 2011 8:02 pm
Jim, of the back of my head I reckon the the engine speed/road speed ratio in auto 3rd should be somewhere around 20mph/1000rpm in a 2000 (3.7:1 diff), a 2.5 even better I suppose. So if your rev counter is correct, there's something wrong... I'm not sure how far off a 4.1:1 diff would get you?!
Rgds
Thorsten
Register Member No 6967-06/01
kevinw
#19
Post
by kevinw » Tue Nov 01, 2011 8:34 pm
if someone can identify approximately which issue of SIXappeal the original article appeared in, I could reprint it. I have the "official" archive, but the problem is that only the last 3 year's worth are electronic and the preceding 27 years worth are on hard copy - and that takes up the best part of a filing cabinet - so a lot to search through.
They are all indexed, so if I know approximately which issue, it is much easier to find for a reprint.
Kevin
Kevin Warrington
#20
Post
by sorbs » Thu Nov 03, 2011 7:29 pm
I think a 2000 with direct drive (4th on a non overdrive manual) gives about 16.7mph/1000rpm? So a true 80mph (probably 90 on the speedo) would give 4800rpm. That's with a 4.1:1 diff.
A 2000 auto should have a 3.7:1 diff giving 18.75mph/1000rpm so 4250rpm at a true 80mph.
All 2500s should have a 3.45:1 diff giving around 20mph/1000rpm in direct drive top, 3rd on an auto, 4th on a manual.
5000rpm at a true 70mph tends to indicate a problem with the rev counter reading, diff ratio or maybe a slipping transmission.
