It is currently Fri Sep 10, 2010 6:00 am
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: J Type overdrive issues!
PostPosted: Fri Jul 23, 2010 11:51 am
Offline
I need help! (Not professional-I've had that-it doesn't work! :| )
The overdrive on my Mk2 estate works fine when cold, but once the car has warmed up it refuses to go in! On the rare occasions that it does go in I get a 'clutch slipping' feeling?
I know nothing about these gearboxes so any suggestions would be helpful.
The gearbox oil was checked before the HCR and the car hasn't been used much since then. I will be checking it again this weekend, but wondered if there's anything else I can check whilst under the car?
Thanks in advance.
Top
 Profile
 Post subject: Re: J Type overdrive issues!
PostPosted: Fri Jul 23, 2010 12:57 pm
Offline
You could try cleaning out the filter. This is inside the rectangular alloy cover at the bottom of the OD unit held on by six bolts. :)
_________________
Register Deputy Chairman and Director member 3095
Folkestone Kent
Vermillion Red Spitfire1500
Pimento Red Stag
Top
 Profile
PostPosted: Fri Jul 23, 2010 10:01 pm
Offline
Hi, You say oil was checked, was it drained and refilled or just the level checked?
If only level checked I wonder how long the oil has been in there.
Maybe some fresh oil would be a good place to start.
_________________
1976 2500 TC
1978 2500 S
1990 Peugeot 405
If all else fails.....read the instructions!!!
Top
 Profile
PostPosted: Fri Jul 23, 2010 10:50 pm
Offline
well, seeing as it was a nice evening (and that there was bugger all on Tv) I decided to have a look.
The oil level was fine (In fact it started running out as soon as I undone the filler)
So I undid the sump. The filter looks fine and the rest of the parts looked clean abd grit free too. I will give them a proper clean tomorrow and refit them. (Although I need a new gearbox sump gasket-any idea where I can get one of these?)
The oil didn't look that great I have to say, so maybe I'll drain and replace anyway.
Then maybe check the solenoid out.
Top
 Profile
PostPosted: Sat Jul 24, 2010 3:45 am
Offline
Just one other thought.
I had all sorts of hassles with my S's overdrive either not engaging or dropping out by itself.
Turned out to be the gear lever switch.
All my o/d problems have been electrical, loose or dirty connectors or bad earths.Or bad switches.
I've put relays in all my overdrives. Probably not really necessary on J types but I then know the little switch on the gear lever is only carrying relay coil current.
J type solenoids either work or don't work.They don't come apart. Good luck, I'm sure it's something simple. :)
_________________
1976 2500 TC
1978 2500 S
1990 Peugeot 405
Top
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
