Distributor Rebuild query
Carboy0
#1 Post by Carboy0 » Sat Mar 09, 2019 5:18 pm
I am rebuilding a 2500S 45D6 distributor that I picked up at Stoneleigh the other week. It’s come apart fairly well and there is negligible wear on the shaft or the housing, so it’s good to go again.
I need to replace the O ring on the housing, can anyone advise the part number and a source, or alternatively the size (imperial).
The usually very helpful Rimmers website doesn’t list the part.
Thanks in advance.
Chris
Member 7910
Magenta Stag 3.0 Man O/D
Re: Distributor Rebuild query
#2 Post by johnnydog » Sat Mar 09, 2019 8:13 pm
According to the parts book, it is 513862.
Chris Witor is usually the best source of both info and parts for our Triumphs. I haven't bought anything from Rimmers for years........
herald1360
#3 Post by herald1360 » Sat Mar 09, 2019 10:38 pm
Distributor Doctor would be able to supply any parts you need, all good quality
Regards
Paul Barlow
Exeter
1974 2500TC French blue
Carboy0
#4 Post by Carboy0 » Sat Mar 09, 2019 11:38 pm
Thanks Guys, I have emailed the DD.
I don’t generally use Rimmers for parts, but their online parts catalogue is normally great for identifying part numbers etc.
Chris
Member 7910
Carboy0
#5 Post by Carboy0 » Sat Mar 09, 2019 11:51 pm
Can you confirm the part number, I can find 513682, but not 513862.
Chris
Member 7910
#6 Post by johnnydog » Sun Mar 10, 2019 10:02 am
Sorry, a slip of the digit (!), it is 513682 - my apologies!!
Carboy0
#7 Post by Carboy0 » Sun Mar 10, 2019 1:01 pm
Chris
Member 7910
#8 Post by Alec » Mon Mar 11, 2019 12:39 pm
Hello Carboy0,
did you check the number stamped on the distributor to verify it is correct for your engine?
Jaguar X Type Estate 2.5
Carboy0
#9 Post by Carboy0 » Tue Mar 12, 2019 8:28 am
Hi Alec,
Yes thanks, checked and cross-checked.
The Distributor Doctor has sorted me out the correct £0.75 ‘O’ ring.
Chris
Member 7910
