Hello,
One of my courtesy light switches has failed, lost it's spring, I have repaired it by dismantling and fitting a new small spring between the end of the plunger and the body of the switch. Meanwhile I thought that I would get some stock in but Rimmers, Witor, and other well known names are out of stock, I see plastic switches for as little as £1.75 on ebay which I suppose need modifying to earth properly, does anyone know of any original stock anywhere ?
Thanks,
Michael.
Re: courtesy light switch
I have a few good used ones if you want one.
John
John
I am also local to you which may make it easier!
Hi Johnnydog
sorry I am slow to reply, I'm in Rossendale and I tried to send a pm but must have done it wrong, I'll have another go,
Thanks,
Mike
Thanks,
Mike
I did send you a reply to your PM Mike, but in case you didn't get it, I've sent you another.
