Tachometer / Rev Counter Stopped Working
Re: Tachometer / Rev Counter Stopped Working
#11 Post by Mike Stevens » Tue Apr 04, 2017 10:44 am
In my experience, most cars speedos seem to over-read when compared with a satnav. The satnav should be pretty accurate when the speed is constant, but I suspect that they will lag behind a bit when the speed is changing. This is probably due to the update rate that the GPS engine uses.
David - that sounds like a good method to check the calibration. I have found that some tachos have a 'pot' inside to adjust the calibration, while some (maybe later ones?) don't. I use a low frequency signal generator coupled to the tacho input and to a digital frequency meter so I can check the signal generator frequency. A bit of calculation gives the frequencies corresponding to revs and so far it seems to be OK!
I've also been trying to find a suitable way to check the calibration of a speedo. The obvious choice is a 'stepper motor' which you can accurately define the motor RPM. Sadly, I've not found a suitable one yet!
Submitting your article to Kevin is by far the best approach. I shall look forward to seeing it!
David Withers
#12 Post by David Withers » Tue Apr 04, 2017 3:22 pm
My tacho is the type fitted to many cars in the late-60s/early-70s and it has a trimmer accessed by screwdriver through a hole in the back of the housing (so the instrument has to be outside the panel for adjusting).
Re: Sat-nav accuracy: Last year my son and I went on a 150 mile journey in his car. As 'navigator' I set my Garmin for the trip, however he'd set his TomTom so we let both run for comparison (with his muted). I didn't see any differences in displayed speeds, though I couldn't tell you about lag as I only did spot checks from time to time.
#13 Post by Mike Stevens » Sat Jun 10, 2017 10:27 pm
Good article David. I enjoyed that. Of course, being an electronic engineer means I was a bit biased!
David Withers
#14 Post by David Withers » Sun Jun 11, 2017 7:31 am
Mike Stevens wrote:Good article David. I enjoyed that. Of course, being an electronic engineer means I was a bit biased!
Thank you, Mike.
Not being at all confident with electronics, I was very pleased - and perhaps a little surprised - that the repair went so well. That tacho should now be fine for another 45 years!
torque2me
#15 Post by torque2me » Wed Jun 14, 2017 4:47 pm
Mike Stevens wrote:In my experience, most cars speedos seem to over-read when compared with a satnav. The satnav should be pretty accurate when the speed is constant, but I suspect that they will lag behind a bit when the speed is changing. This is probably due to the update rate that the GPS engine uses.
4 seconds.
