Hello Llessur,
as I said " usually by one of the engine mounts connecting the two",
i.e. a strap on the engine side of the mount to the body side of the mount, it's quite short maybe 4 inches or so?
Hazards and indicators
Re: Hazards and indicators
Whilst you seem to be on top of the indicator issues, the hazard problem is the switch itself. It is designed to isolate the indicator circuit with the flasher unit in it, and make another circuit connecting both left and right sides together using the hazard flasher unit. The connections are by a copper ring and various terminals on the switch itself. These become dirty and do not provide a decent contact. To re4move the switch is easy, remove the dash wood panel, disconnect the switch from the panel and unplug. Clean and replace. Just takes a little time. Good luck.
It could also be a problem with the hazard flasher itself. The hazards use a 2nd flasher unit which might be faulty or even missing!
On a Mk2, the engine earth strap should be on the LH side of the engine. I think!
Cheers Alec - I just wondered where exactly the body end of the cable/strap usually connects to. On the engine side I'll just pick a nearby timing cover bolt or something but if there's already an existing connection point on the body somewhere that would be useful.Alec wrote:as I said " usually by one of the engine mounts connecting the two", i.e. a strap on the engine side of the mount to the body side of the mount, it's quite short maybe 4 inches or so?
Which side of the car is it usually on? Battery or carbs? I presume it should be towards the front by the engine mount and not between the gearbox bell housing and the bulkhead like I remember on the Spit/GT6?
Unless it was one of those Triumph things that seems to change randomly from car to car...
Thanks Charles - I've got a couple of spare dashes lying around so I'll swap the switch over from one of those, or just get the contact cleaner out, and see whether that helps.Charles H wrote:Whilst you seem to be on top of the indicator issues, the hazard problem is the switch itself. It is designed to isolate the indicator circuit with the flasher unit in it, and make another circuit connecting both left and right sides together using the hazard flasher unit. The connections are by a copper ring and various terminals on the switch itself. These become dirty and do not provide a decent contact. To re4move the switch is easy, remove the dash wood panel, disconnect the switch from the panel and unplug. Clean and replace. Just takes a little time. Good luck.
Cheers Mike - if the switch cleaning/replacement doesn't work then I will take a look and see if I can find a good replacement flasher to swap in to test. Otherwise will look into the advice above about fitting a modern electric flasher unit.Mike Stevens wrote:It could also be a problem with the hazard flasher itself. The hazards use a 2nd flasher unit which might be faulty or even missing!
I know of the indicator flasher unit under the passenger side dash but do you know where the second flasher for the hazards is? If they worked that would help me locate it I guess...
1977 2500S - White
1977 2500S - White
