Wipers
Posted: Sun Jan 17, 2016 10:10 pm
by CP Sargent
Hi all
The wipers on my mk1 are very slow to come on when I flick the switch on and then work there way slowly across the screen is it the switch or the wiper motor or where should I be looking cheers Pete
Re: Wipers
Posted: Mon Jan 18, 2016 2:49 am
by tony
Probably the motor. Brushes and / bearings usual suspects or could be semi seized wheel boxes.
Re: Wipers
Posted: Mon Jan 18, 2016 8:32 am
by david_rachel
You might be lucky and be able to sort it by re-greasing the rack.....try turning the wheel box spindles 180 deg before re-inserting the rack, and also turn that 180 deg and you might be okay
