2 used, 2 new and I still haven't got a working fuel gauge sender!
The 2 used were used....guess that's why they didn't work, one new sender fell to pieces as I took it out of the box (today!), that's still better then the first new one, that wouldn't seal and leaked petrol, a lot!
Has anyone got a sender, which they know works, for sale please?
This has been on-going since the last 2000 Register Nats!
Andy
Fuel tank sender needed please
Re: Fuel tank sender needed please
I had the same problem regarding leaking with a new sender unit.
I ended up nicking the rubber gasket off my Vitesse in the end to stop it leaking.
Also, the retaining rings are much weaker. I broke off the lugs used to tighten it and then realised (when it was in a position to never be moved again) that I hadn't adjusted the float properly and now 1/2 full is empty!
- johnconradlee
Yup I did that as well....and then realised (when it was in a position to never be moved again) that I hadn't adjusted the float properly and now 1/2 full is empty!
That was a year ago, and I'm wondering when (if ever) I can be bothered to fix it.
