OK now got the engine home, but it will have to wait a while before I get to look at it properly as I have two other engines ahead of it awaiting rebuilds.(Little A series for two friends with A35s which I can do with my eyes closed),
As far as I can tell what I need is a timing cover, rocker assembly, pushrods , a dipstick (!!) and , because it only has three head studs, a set of studs nuts and washers which I see are quire costly.
The head number is 516816 which seems to be the right one to go with the engine number so 8.125" pushrods seem to be the ones ?
If anyone can help please let me know (jonnydog ?)
WANTED - rocker assembly and pushrods
Re: WANTED - rocker assembly and pushrods
I will start checking what I have and let you know in the week.
Just to confirm - do you want the studs in the block for the head, or the studs in the head for the rocker / rocker cover assembly?
Sorry if I have not understood you correctly!!
Looks like I need both !
Thank you for looking for me.
So far I have found the following parts you require -
Rocker shaft complete plus studs if required
8.125 pushrods - set
2.5 timing cover and fastenings
Dipstick
14 cylinder head studs - 7/16ths unf plus nuts washers etc
Rocker cover studs
I have sent you a pm......
Dipstick
Rocker cover studs
That is great - thank you.
Can,t see a PM I am afraid.
Do I need to do anything other than click on "private messages" at the top right to see it ?
I have received from another two private messages and can see those by doing so so not sure what is going wrong.
I am on 07941 449277 if you wanted to call this weekend perhaps ?
Thanks for the info. I have had pm's previously that haven't got to the intended recipitant - perhaps it is me!
I have now sent you a email and will be in touch Monday.
