englishbull
#21
Post
by englishbull » Tue Feb 11, 2014 1:19 pm
Mike Stevens wrote:I also wonder if some of the old ones leak. They are supposed to be sealed beam, but if air can get in it will burn out the filament pretty quickly. I too have seen a blue colour appearing on the glass sometimes.
Jim, do you still want some more from me next month?
From his postings he needs a boot full for every outing
1964 MK1 Cactus over Conifer
1966 Mk1 estate
1968 MK1 PI In Jasmine
1995 Rover 820 Vitesse Turbo
x3 1962 Triumph Tina scooters
JimB
#22
Post
by JimB » Tue Feb 11, 2014 2:19 pm
CRAJ wrote:englishbull wrote:Had this on the estate would fit and try and all fine but put all trim back on and one would blow.
Found out it was the pin socket not.connecting correctly or at least that cured.the issue
I think Lee has a possible answer there.
A loose connection on one pin would cause a heat build up and could lead to a blown lamp, or worse still a small fire. It's worth checking if you need to change a lamp or Halogen filament lamp.
I fear it was just Sod's Law in action... I've never touched the left outer unit and the connector and incoming wires were fine, with no signs of burning.
JimB
#23
Post
by JimB » Tue Feb 11, 2014 2:20 pm
Yes Mike, the lamp was indeed blooming at the top so I guess the vacuum had been lost over a short time.
And yes, again, to any spares you have!
TedTaylor
#24
Post
by TedTaylor » Tue Feb 11, 2014 4:01 pm
Perhaps carry a torch with a magnet attached to it for emergencies?
MUT
#25
Post
by Mike Stevens » Wed Feb 12, 2014 12:47 pm
JimB wrote:And yes, again, to any spares you have
OK, I'll endeavour to bring a bagfull. Both types or just dip/main?
I'm sure 'blooming' wasn't the only word you used to describe the blown ones!
JimB
#26
Post
by JimB » Wed Feb 12, 2014 9:53 pm
Mike Stevens wrote:JimB wrote:And yes, again, to any spares you have
Thank you! I've got one main left and have already used the two dip/mains from His Tedness
I have to admit that I simply sighed when I discovered to offending lamp...life's to short to worry about small stuff like this
#27
Post
by Mike Stevens » Thu Feb 13, 2014 12:54 pm
JimB wrote:simply sighed when I discovered to offending lamp
Sigh doesn't quite cover my thoughts when my PC produce 4 BSODs last night!
kevinw
#28
Post
by kevinw » Sat Feb 15, 2014 9:24 am
At least our cars don't BSOD. Our modern car has a radio (for want of a better word as it also plays CDs, DVDs, MP3s and has a built it in satnav) that is based on Windows Mobile. If I was to put that into the 2000, I'd have the best of everything. Lucas electricals and Microsoft software. What could possibly go wrong?
Kevin
Kevin Warrington
TedTaylor
#29
Post
by TedTaylor » Sat Feb 15, 2014 5:51 pm
#30
Post
by Mike Stevens » Sat Feb 15, 2014 8:48 pm
kevinw wrote:Lucas electricals and Microsoft software. What could possibly go wrong?
No problem. You just stop at the side of the road, give it the 3-fingered salute, reboot and carry on. That's what we do with our PCs after all...
