WANTED: alloy rocker cover fixing nuts x3
red2000chris
#1 Post by red2000chris » Mon Mar 04, 2013 7:23 pm
has anyone got any fixing nuts they dont need for the rimmers alloy rocker cover?
if so, let me know price inc postage and will send cheque. ta. :D :D :D
TedTaylor
Re: WANTED: alloy rocker cover fixing nuts x3
#2 Post by TedTaylor » Mon Mar 04, 2013 9:31 pm
Did it come from Bedford by any chance ...... :lol: I was after some once and they were not available separately though may possibly be able to find the ones that I had off this cover (which the Bedford guy still owes me for).
You can use a fibre washer that is a tight fit on the stud and a washer to protect it before using a nylock nut to screw it down. This should provide sealing to all potential leak points.
You may be able to make the Mini ones fit - they are the ones I bought (off ebay) for my SAH covers (not from Bedford or Caister .....). If you do try them they will require the hole in the cover to be opened out and I am not sure whether the length of the stud is OK because these nuts are blind.
Ted
SeanMk12000
#3 Post by SeanMk12000 » Mon Mar 04, 2013 11:37 pm
Have you looked into the Austin C series ones I suggested?
I'm 90% sure they will suffice
TedTaylor
#4 Post by TedTaylor » Tue Mar 05, 2013 12:25 am
If I can find them mine are original chrome ones - the Mini ones are also nicely chromed and quite cheap.
Ted
TedTaylor
#5 Post by TedTaylor » Tue Mar 05, 2013 9:49 am
TedTaylor wrote:If I can find them mine are original chrome ones - the Mini ones are also nicely chromed and quite cheap.
Ted
Found them.
Ted
red2000chris
#6 Post by red2000chris » Tue Mar 05, 2013 8:37 pm
TedTaylor wrote:Did it come from Bedford by any chance ...... :lol: I was after some once and they were not available separately though may possibly be able to find the ones that I had off this cover (which the Bedford guy still owes me for).
Ted
with the alloy cover on the car, the studs dont stand above the holes so normal nuts are no good.
red2000chris
#7 Post by red2000chris » Tue Mar 05, 2013 8:39 pm
hi sean, im looking generally at the mo so will look at all types. :)
TedTaylor
#8 Post by TedTaylor » Tue Mar 05, 2013 11:24 pm
Ted
Found them.
Ted
The correct ones for this cover.
red2000chris
#9 Post by red2000chris » Wed Mar 06, 2013 6:35 pm
thanks ted. PM sent. :D
Lloydpiestate
#10 Post by Lloydpiestate » Wed Mar 06, 2013 8:32 pm
ted,
i need 3 for a triumph tune one i picked up last week, any chance ??????
cheers matey
lloyd
