rack boots
johnboy
rack boots
#1 Post by johnboy » Mon Jul 24, 2023 5:17 pm
Hi, does anyone know if the steering rack boots ( non P.A.S.) are different for the MK 2 2000 T.C. (1977) from the earlier MK 2. I got a pair of boots but they are too small in diameter. I thought all non PAS boots were the same? cheers.
Re: rack boots
#2 Post by johnnydog » Mon Jul 24, 2023 9:13 pm
As the standard non pas steering racks for all models in the range are the same, then it stands to reason the boots are the same. Are the boots genuine Stanpart / Unipart / Rover, or an aftermarket version that claim to fit the 2000?
Don't forget that the inboard end of the two boots per rack are different - one has a much larger id hole....
johnboy
Re: rack boots
#3 Post by johnboy » Tue Jul 25, 2023 12:40 pm
Thanks for that . I knew they were sided but i purchased "shaftec " make ,but are too small in diameter. I don't know where I would get genuine unipart / Rover ?
Re: rack boots
#4 Post by johnnydog » Tue Jul 25, 2023 2:20 pm
I think your best bet would be Chris Witor. At least you know they will be the correct fit for your car...
johnboy
Re: rack boots
#5 Post by johnboy » Tue Jul 25, 2023 6:04 pm
Cheers.
johnboy
Re: rack boots
#6 Post by johnboy » Thu Aug 03, 2023 2:47 pm
A TIP for anyone else fitting these boots- Steep them in boiling water for 15 minutes and they will go on a lot easier. Cheers all.
