That is one option that Bill suggests; however fitting 13" PI wheel trims to a 14" Stag steel wheel causes the valve stem being bent over, which could in turn cause premature failure which you wouldn't want on the road...! That is why Stag rostyle trims had an oval hole for the valve stem as opposed to the round hole on the PI wheel trim. If going down the Stag steels route, then I'd fit Stag wheel trims - they are relatively easy to find. I saw several at Stoneleigh a couple of weekends ago...the beauty is most sellers don't know the difference which keeps the price down !
Incidentally, for anyone who maybe interested, My Tyres have now stocks of Maxxis 185 80 13 tyres at the best price I could find anywhere - I only know because I purchased a set this morning!
£116.19 each delivered, excluding fitting - far cheaper than Vintage Tyres at £109 each + vat and possibly delivery on top (£130.80 delivered on EBay), or BuyCarParts at £114.18 each but with delivery costs on top.
185 80 13
Re: 185 80 13
All interesting stuff. I think you also have to think about the steering. I think some of these tyres will be a devil to steer with if they are not the actual size.
What do you think about that?
I will probably get some Maxxis ones and see what happens.
Jeff
Jeff
Triumph 2.5PI Valencia
Re: 185 80 13
John,
Did I wet your appetite for new tyres
Re: 185 80 13
I think you spurred me into getting another set Jeff - I did actually need some for my white PI!
https://www.mytyres.co.uk/rshop/tyre/Ma ... m/R-220107
