Brakes won,t bleed
Re: Brakes won,t bleed
#21 Post by Dave B » Wed Feb 11, 2015 8:16 pm
I am a relative newcomer to the Eezibleed method, but I soon discovered that the lower the pressure used, ie 2 to 3 psi gave good results with no leakage. Use it straight off an inflated tyre = brake fluid everywhere!
CAR
#22 Post by CAR » Wed Feb 11, 2015 8:46 pm
Dave B wrote:I am a relative newcomer to the Eezibleed method, but I soon discovered that the lower the pressure used, ie 2 to 3 psi gave good results with no leakage. Use it straight off an inflated tyre = brake fluid everywhere!
I agree Dave, the 20psi that I recall they recommend is too much. Also I have found that the best way to get a good seal on the m/c is to sacrifice a master cylinder cap, certainly works well with the Stag one on FRanK.
#23 Post by tony » Thu Feb 12, 2015 4:20 am
Bike Pump ?
#24 Post by Mike Stevens » Thu Feb 12, 2015 12:37 pm
johnconradlee wrote: read the Eezibleed instructions
C'mon, read the instructions? That's the last resort innit? :wink:
#25 Post by Clifford Pope » Thu Feb 12, 2015 12:39 pm
Bike tube might be a good idea. Low pressure, and you can rest it on top of the wing without risk of damage.
johnconradlee
#26 Post by johnconradlee » Thu Feb 12, 2015 1:14 pm
Maybe a wheelbarrow inner tube or car inner tube?
