sump guard MK1
widget
sump guard MK1
#1 Post by widget » Sun Feb 15, 2015 11:57 am
want/need to get one made up for my MK1 ...does anyone have the dimensions to hand...a pic or even better, one i could borrow to copy?
MK1 2000
Herald 1200
MK3 Fiesta
leesellars
Re: sump guard MK1
#2 Post by leesellars » Mon Feb 16, 2015 11:25 pm
Widget
You want a alli plate 1000mm x 600mm wide. 6mm or 8mm. flat plate. It cost me about £120.00 to get mine made. You will have to weld underneath on the legs two brackets and a frame made to go underneath the engine cross member.
Triumph Mk2 PI 1975
Triumph TR6 PI 1973
widget
Re: sump guard MK1
#3 Post by widget » Tue Feb 17, 2015 8:56 am
thanks for that..most helpfull
MK1 2000
Herald 1200
MK3 Fiesta
Re: sump guard MK1
#4 Post by Charles H » Wed Feb 18, 2015 6:19 pm
I just use a chicane two part guard. Just bolts on a Mk2, needs a inch or so trimmed off the front section for a Mk1!
Pimento Red Stag
widget
Re: sump guard MK1
#5 Post by widget » Fri Feb 20, 2015 5:31 am
where does one get one ?
MK1 2000
Herald 1200
MK3 Fiesta
Re: sump guard MK1
#6 Post by Charles H » Fri Feb 20, 2015 9:55 am
I was given one! Try putting a post in the wanted section. Someone may have one. :D
Pimento Red Stag
