I have seen a nice solution for tr6 driveshaft with cv and a new hub (limora.com). I was wondering if it is possible to mount these on an 2500 estate?
Does any one have some experience with these conversions ?
Also Weslake has an BMW diff conversion for the stag.
But doesn't react on mine mails.
Who has experience with Weslake automotive?
Edwin
Tr6 driveshaft vs 2500 driveshaft
- Andy Thompson
Re: Tr6 driveshaft vs 2500 driveshaft
Look at goodparts (USA based)
They do an Uprated hub and CV shaft conversion
https://www.goodparts.com/shop/index.ph ... ductID=823
Perth WA
1970 2500PI estate
1964 2.7PI saloon
1973 2100 EFI Megasquirt
1972 Stag
Very Big garage
1970 2500PI estate
1964 2.7PI saloon
1972 Stag
Very Big garage
- leesellars
Tr6 Shafts are a different lenth than saloon
Triumph Mk2 PI 1975
Triumph TR6 PI 1973
Triumph TR6 PI 1973
Hi Edwin,
as Lee pointed out the TR shafts are shorter than saloon shafts.
If you are referring to a Mk2 Estate you could use the CV driveshafts offered for the Stag which are the correct length. I am using these CV driveshafts since 2004 (approx. 60,000 kms) in my 2000 Mk2 Estate and 2.5 PI without a problem so far. These shafts were from TR Nord, a Triumph workshop near Hamburg, Germany. They invented these driveshafts for the TR roadsters and later on assembled a small batch for the Stag as well.
As far as I know, Limora initially distributed the TR Nord items but are offering their own product now (which doesn't necessarily makes it better, I guess).
Their hompage is http://www.tr-nord.de/ only in German, though.
Kind regards
Thorsten
Kind regards
Thorsten
Register Member No 6967-06/01
Thanks every one,
I will send some mails to the mentioned enterprises.
Will keep you informed
Hi,
I found a set from limora Berlin.
I have mounted them a week a go and I am very happy with the handling of the car.
It doesn't tweak any more when accelerating hard in a bent and then changing gears.
I Still have a lot of rumbling in the rear. So that will mean another diff.
Thanks every one
Thanks every one
