engine cooling
hi all ive been searching for a cooling fan switch and found this company mawsolutions.com that specialise in vehicle cooling they sell screw in variable temperature fan switchs in bsp metric and npt threads with a temp range of 70deg c to 120deg c. i dont suppose there cheap but should be better than the capillary type that fit in the top hose, what temperature should the fan cut in and out at? i was thinking it should cut in at 100deg c and out at 85deg c,
1972 mk2 triumph 2000 converted to 2500 overdrive gearbox
1989 mercedes 190e 2.6 auto
- leesellars
Re: engine cooling
Hello Iggy
Mine is set up with a 82 stat. Fan cuts in at 95 and cut out at 85. This keeps the stat open all the time.
Triumph Mk2 PI 1975
Triumph TR6 PI 1973
Triumph TR6 PI 1973
Re: engine cooling
thanks lee my temp guage has never reached half way ive only had the car for about six weeks so never run it in warmer weather, but the heater gets nice and hot though, ive got a couple of 10" electric fans and a relay i intend to remove the viscious fan and fit the 2 electric ones at some stage so the engine should warm up quicker, really need to buy a recon diff first though any ideas where i can buy one in the south east
- leesellars
Re: engine cooling
Hello Iggy
The general consensus on here is to use Mike Papworth but he is in Conventry. I use TR Enterprises as the are closer to me.
Triumph Mk2 PI 1975
Triumph TR6 PI 1973
Triumph TR6 PI 1973
Re: engine cooling
[quote="iggy"] my temp guage has never reached half way
Try substituting the temp. sender unit first, it could be giving a low (false) reading if the heater is hot enough.
When I first got my current 2000, the needle hardly moved off the stop, but gave a normal reading after changing the sender unit.
Re: engine cooling
ok dave b il take your advice thanks
- david_lall
Re: engine cooling
I don't know if you can do this on all 2000's but my 2.5PI has PAS - so the radiator bottom hose has a short metal piece. I purchased a thermal switch from Moss for around a tenner, cut a hole in the metal pipe and had brazed on a nut. Wired it up and hey presto, auxillary electric fan cuts in/out automatically.....non of the Kenlowe top hose capillary tube rubbish to worry about!
David Lall
1978 Carlight Casetta Caravan
Re: engine cooling
A rad place will put a boss in your rad for not very much money.
1969 2000 MkI EFI
1969 Spitfire MkIII
1969 Spitfire MkIII
- david_lall
Re: engine cooling
Yes, that's also true - had it done on my MG 1300 this time last year and then fitted a Revotec electronic fan controller as they allow infinite temperature setting - it's actually a much better option (but more expensive).
David Lall
Re: engine cooling
My pi never reaches halfway either, usually sits at 1/3rd to just below halfway, the estate used to always sit at nearly 2/3rds until I changed the stat for one from CW. It now sits at just below halfway. Both heaters get good and warm.iggy wrote:thanks lee my temp guage has never reached half way ive only had the car for about six weeks so never run it in warmer weather, but the heater gets nice and hot though
If I was you I wouldn't worry about the temp. reading, sounds just right to me.
