Hi Jonathan
Not to hijack teds tread again
Not sure, but I have an idea that the P6 diff might also have been Salisbury-based if that's any help for parts?
Just got back from my mates engineering workshop with a new quill shaft for fitting the p6 diff to a triumph subframe thought you mite be interested
Ken
P6 Diff
- Attachments
Ken Bryant
Register Member 4134
4.3 V8 PI Saloon BRG
http://triumphowners.com/1008
3.8 vs Commodore on lpg
- Jonathan Lewis
Re: P6 Diff
Thanks, Ken - interesting. Presumably the set-up also requires a modified flange on the Triumph nosepiece to bolt to the P6 diff?
Regards,
Jonathan
Regards,
Jonathan
Re: P6 Diff
Hi Jonathan
yes it an esey one just cut off the square triumph mount and turn down a mild steel bar to the outside diameter of the triumph quillshaft housing press on and weld round drill the six holes in the new housing and bolt on. Apiece of angle iron acrossthe back of the diff with some shocker bushes and some tube for spacers and that mounted driveshaft flanges on the diff have to be redrilled to take the driveshafts with a spacer on the driverside as the diff from the P6 is narrower by 2 inches> I have to get the car up off all four wheels to fit a new flywheel and clutch soon and clean and repaint underneth so ill take some pictures and post them for you
Ken
Ken
Ken Bryant
Re: P6 Diff
I am just making the spacers to fit a p6 diff into my V8 MK11. The nose piece doesnt look too bad - just the seal may be a nightmare! Ken sorted me a quill shaft before he went, but I cannot remember how he said to harden it. I am currently going to case harden to 40 rockwell - anyone know if that is right?
I think only Ken and Roger Keys (Orange V8 estate) have fitted the p6 diff so far? It seams the only way to get better than 3:45:1 in the UK, unless you go the BMW route?
Any photos or extra details would be much appreciated.
David
David
- Andy Thompson
Re: P6 Diff
http://www.cheltenhamheattreat.co.uk/
Spoke to Ken - I think this is the place and he said 95 Rockwell
Perth WA
1970 2500PI estate
1964 2.7PI saloon
1973 2100 EFI Megasquirt
1972 Stag
Very Big garage
1970 2500PI estate
1964 2.7PI saloon
1972 Stag
Very Big garage
Re: P6 Diff
They were the guys I had already spoken too! They will check the hardness of the original shaft, and try to make the machined one the same, but are adament that 95 rockwell is way too high and infact unachievable!
Unfortunately they do not remember the job, nor the name
Looks like I will have approx 40 rockwell and see if it is good enough!
Lots of spacers to make before we get that far though!
Re: P6 Diff
P6 diffs are bad starting point for upgrading something else, as even in their best form they're a very weak unit. They're nothing like a Salisbury, in fact, they're not like anything else I can think of. Behind the 4 cylinder engines they were OK, but that wasn't a powerful engine for it's capacity, but behind the V8 they left a trail of broken planet gears and output shafts lying in their wake.
Re: P6 Diff
With Ken running a 4.3 V8 and not having broken one yet, it should be good enough for me with only an LPG fuelled, currently carb fed, 3.5V8!
He shredded a number of standard 2.5 units before "upgrading" to p6. I have one so will give it a try. Cheaper than 1k for a BMW!
