Mk 1 2000 to 2500tc or 2.5pi
I have a standard tank that I am using for (electronic) injection.
The CAV filter I am using works as a perfect swirl pot— though I haven't tested it on track yet. It certainly works on a low tank.
I had to use a standard type of filter at the weekend after I stripped a thread on the CAV filter head. It was useless
1969 2000 MkI EFI
1969 Spitfire MkIII
1969 Spitfire MkIII
- Andy Thompson
Re: Mk 1 2000 to 2500tc or 2.5pi
I fitted mk1 cowls to Mk2 instruments.... alternately keep the Mk1 dialsAlec wrote:Hello Steve,
again I'd forgotten that the Mk2 instruments are a (slightly?) smaller diameter, I think I used a sheet of aluminium to enable them to fit the Mk 1. Alec
Perth WA
1970 2500PI estate
1964 2.7PI saloon
1973 2100 EFI Megasquirt
1972 Stag
Very Big garage
1970 2500PI estate
1964 2.7PI saloon
1972 Stag
Very Big garage
Keep the Mk1 dials— Mk2 dials will just look wrong in a Mk1
1969 2000 MkI EFI
1969 Spitfire MkIII
1969 Spitfire MkIII
Hello James\Andy,
I wanted a tachometer, which the Mk 1 never had? and I preferred to have it in the dash rather than the, to me, untidy pod mount. I never did like the white dials of the Mk 1 anyway.
Alec,
I much prefer the late Mk1 black dials to the early white.
I have seen a black (Elliot or Smiths) tacho that looks fairly standard installed in a late Mk1— with separate 2 inch gauges moved to the centre console to replace the standard 3-way.
I have the issue of lacking a tacho— I plan to use the choke light as a shift light— I only need it to know when I am red-lining it?
I no longer have a choke so will replace the choke pull with a push button to spin the engine over for oil pressure— otherwise it starts instantly.
James
James
1969 2000 MkI EFI
1969 Spitfire MkIII
1969 Spitfire MkIII
I like the white dials! I don't want a tacho in mine....it would frighten me! Ask the polisher!
What about the narrower gearbox tunnel on the pre-facelift cars?
Not a problem unless you go for a 6 - 3 - 1 manifold. The tunnel will then need 'dressing with a large tube shaped dolly and a hammer! One of the reasons mine hasn't got one! The other is the ££££s The larger bore pipe needs very careful routing to avoid it touching the bodywork! Know all about that one!
Hi Alec, I see you have a Mk2 steering column with all its switches and lock. How do you do that ? I thought about that on my Mk1 - but it would need all the Mk2 body brackets; parts of it suck out in the wrong place, so I thought too much trouble. The real advantage being that a Mk1 boss is no longer available for my fancy steering wheel. or is there another bodge.
Steve Knight
Hello Steve,
sorry for the slow response but I've been without a P.C. while doing some house work. (Not housework ).
It is a mixture of Mk 2 and Mk 1 column. Unfortunately I don't remeber exactly what I had to do, I do know I had to chop (Shorten I think?) the section from the column to the rack to make it all work. I didn't use the steering column ignition switch but kept the Mk 1 dash switch.
I could remove the shroud and take a picture if that will help you?
