Megasquirt parts
Where have you plumbed the servo into, the airbox?
Andy
Andy
Re: Megasquirt parts
My main problem is that my local engine machine workshop is entirely staffed by miserable, unhelpful, rip off w**k**s!
Need to find some one better, or I'm going to struggle.
Andy
Andy
- Andy Thompson
Thats what I used - just araldited a brass fitting into the tube on the plenum log usually used for the engine breather - works fine. I used the other tube (idle air on a PI) for the MAP sensor. Very steady reading - I used the tube closest to the throttle body for MAP so it gets the quickest reaction - probably unnecessaryandyborris wrote:Where have you plumbed the servo into, the airbox?
Andy
http://3.bp.blogspot.com/_Nruu4hyP8gY/S ... CF6173.JPG
Perth WA
1970 2500PI estate
1964 2.7PI saloon
1973 2100 EFI Megasquirt
1972 Stag
Very Big garage
1970 2500PI estate
1964 2.7PI saloon
1972 Stag
Very Big garage
Hello Andy,
if you are going the route of cutting down the boss, it doesn't need to be machined, a few minutes with a hacksaw will do it. Use a new 14 tpi blade and it'll be easy. Dress with a file afterwards.
You don't even need to cut the tops of square. In fact you only really need a tiny slice diagonally off the side.
Block off the holes with grub screws (though I cannot find any 5/8 size) or do as I am doing and bung them up with quiksteel stuff.
1969 2000 MkI EFI
1969 Spitfire MkIII
1969 Spitfire MkIII
- Andy Thompson
I used a erm Belt sander -- then used a cut down bolt 1/2 or 9/16 UNF? loctited into the holes and filed as blanking plugs.andyborris wrote:My main problem is that my local engine machine workshop is entirely staffed by miserable, unhelpful, rip off w**k**s!
Andy
Perth WA
1970 2500PI estate
1964 2.7PI saloon
1972 Stag
Very Big garage
1970 2500PI estate
1964 2.7PI saloon
1972 Stag
Very Big garage
Andy Thompson wrote:I used a erm Belt sander -- then used a cut down bolt 1/2 or 9/16 UNF? loctited into the holes and filed as blanking plugs.andyborris wrote:My main problem is that my local engine machine workshop is entirely staffed by miserable, unhelpful, rip off w**k**s!
Andy
Without reading these posts, I'd probably used a angle grinder, so I think a belt sander is quite restrained!
Did it work?
Andy
Hello Andy,
the problem with an angle grinder or even a belt sander is that the conventional abrasives don't work too well with aluminium and clog quite quickly.
- Andy Thompson
P40 on a belt sander used on floor boards was quite sufficient and actually quite restrained. Finished off with a file - you can't see anything under the fuel rail anyway.Alec wrote:Hello Andy,
Perth WA
1970 2500PI estate
1964 2.7PI saloon
1972 Stag
Very Big garage
1970 2500PI estate
1964 2.7PI saloon
1972 Stag
Very Big garage
Hello Andy,
my reference was basically that the commonly available abrasives don't work well on aluminium and so are relatively ineffective. Certainly the coarser grits don't clog quite as quickly, so as to hinder their removal capacity.
