Seat Belts Estate - Fixing points -
Sloppy 2000
#1 Post by Sloppy 2000 » Tue Mar 14, 2017 10:12 pm
The main problem I have is finding the points. I can find 2 centre points, but i can't find the 2 sides. Are there only points in the saloon? seems odd because the estates are obviously a conversion from the saloon.
Could someone perhaps send me a pic of the locations. Like I say, centre ones. yes, sides no, can't find.
Jeff
Triumph 2000 estate mk1 1968
#2 Post by Alan Chatterton » Wed Mar 15, 2017 7:32 am
Outer ones are there. Look inside wheel arch, you'll see the strengthening plate and nut. Poke a sharp screwdriver through to puncture hole in carpet to give you location.
