WATER IN FOOTWELL
- Newbie
I have noticed that the carpets in the drivers side footwell are wet. I have checked the windscreen and it doesn't appear to be leaking. Where else is this likely to be coming from ?
Re: WATER IN FOOTWELL
It will be the windscreen. Unless you have holes in the floor or the sills!
Hello Innsbruck69,
another possible source is the seals on the wiper spindles or the heater box drains are blocked?
The windscreen is the favourite though.
check under the scuttle where the heaterbox seals to the body, thats where mine comes in
- Jonathan Lewis
Also check that the drains at the bottom of the front wings (immediately behind the wheelarches) are clear; in cases where these have become blocked, I have heard of the wing cavities actually beginning to fill with water and overflowing into the front footwells...
- TedTaylor
Check the bulkhead because they can rot, especially where the heater plenum is. Needs removal of the dash to check though ........ which is why I have not done the one on Woody yet!
MUT
MUT
WATER IN FOOTWELL
I'm actually wondering why you are confident it's not the screen? Most will have at least a few pinholes in the metal below the rubber, so the leak would be between metal surround and rubber, so extremely difficult to spot.
And of course if the car is being used, the joint between bulkhead and floor is perfectly placed to receive any spray off the front wheels.
Triumph 2000 Mk1 Slate Grey
Triumph 2.5 PI Mk2 Damson
Landrover Discovery 3.9 V8
Reliant Kitten
MGZS
MGZR
Reliant Kitten
MGZS
MGZR
- Newbie
I don't think it is the screen because I have poured water over it and the inside of the screen, and the inside rubber is bone dry.
- Newbie
- Newbie
